Time Before: 0.00231 seconds
Time After: 0.00291 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00298 seconds
Time After: 0.00339 seconds
Time Before: 0.00356 seconds
Time After: 0.00366 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00434 seconds
Time After: 0.00644 seconds
Time Taken: 0.00209 seconds
Time Before: 0.00371 seconds
Time After: 0.01128 seconds
Time Taken: 0.00757 seconds
Time Before: 0.01349 seconds
Time After: 0.01369 seconds
Time Before: 0.01639 seconds
Time After: 0.01755 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01294 seconds
Time After: 0.01772 seconds
Time Taken: 0.00479 seconds
Time Before: 0.02510 seconds
Time After: 0.02526 seconds
Time Before: 0.02879 seconds
Time After: 0.03007 seconds
End call of global.php: 0.031816005706787
Time Before: 0.03321 seconds
Time After: 0.03337 seconds
Time Before: 0.03594 seconds
Time After: 0.03736 seconds
SET lastactivity = 1788912969, location = '/forums/private.php?do=newpm&explain=1&u=105996'
Time Before: 0.04990 seconds
Time After: 0.05015 seconds
Page generated in 0.048968076705933 seconds with 9 queries, spending 0.0072355270385742 doing MySQL queries and 0.041732549667358 doing PHP things.
