Time Before: 0.02041 seconds
Time After: 0.02564 seconds
Time Taken: 0.00523 seconds
Time Before: 0.02574 seconds
Time After: 0.02683 seconds
Time Taken: 0.00109 seconds
Time Before: 0.02731 seconds
Time After: 0.02770 seconds
Time Before: 0.02846 seconds
Time After: 0.03041 seconds
Time Taken: 0.00195 seconds
Time Before: 0.02777 seconds
Time After: 0.03441 seconds
Time Taken: 0.00665 seconds
Time Before: 0.04018 seconds
Time After: 0.04068 seconds
Time Before: 0.04326 seconds
Time After: 0.04445 seconds
Time Before: 0.03945 seconds
Time After: 0.04468 seconds
Time Before: 0.07234 seconds
Time After: 0.07246 seconds
Time Before: 0.08773 seconds
Time After: 0.08945 seconds
Time Taken: 0.00173 seconds
End call of global.php: 0.091881990432739
Time Before: 0.10000 seconds
Time After: 0.10027 seconds
Time Before: 0.10335 seconds
Time After: 0.10482 seconds
SET lastactivity = 1789127170, location = '/forums/private.php?do=newpm&explain=1&u=106016', badlocation = 1
Time Before: 0.12344 seconds
Time After: 0.12379 seconds
Page generated in 0.12201189994812 seconds with 9 queries, spending 0.0090558528900146 doing MySQL queries and 0.11295604705811 doing PHP things.
