Time Before: 0.01600 seconds
Time After: 0.01955 seconds
Time Taken: 0.00355 seconds
Time Before: 0.01965 seconds
Time After: 0.02006 seconds
Time Before: 0.02028 seconds
Time After: 0.02039 seconds
Time Before: 0.02120 seconds
Time After: 0.02378 seconds
Time Taken: 0.00258 seconds
Time Before: 0.02048 seconds
Time After: 0.02811 seconds
Time Taken: 0.00762 seconds
Time Before: 0.03399 seconds
Time After: 0.03432 seconds
Time Before: 0.03668 seconds
Time After: 0.03791 seconds
Time Before: 0.03332 seconds
Time After: 0.03814 seconds
Time Taken: 0.00482 seconds
Time Before: 0.07320 seconds
Time After: 0.07334 seconds
Time Before: 0.09253 seconds
Time After: 0.09376 seconds
Time Before: 0.10285 seconds
Time After: 0.10299 seconds
Time Before: 0.10515 seconds
Time After: 0.10657 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106051' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.12558 seconds
Time After: 0.12584 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
