Time Before: 0.02384 seconds
Time After: 0.03394 seconds
Time Taken: 0.01010 seconds
Time Before: 0.03403 seconds
Time After: 0.03447 seconds
Time Before: 0.03474 seconds
Time After: 0.03489 seconds
Time Before: 0.03586 seconds
Time After: 0.03842 seconds
Time Taken: 0.00256 seconds
Time Before: 0.03497 seconds
Time After: 0.04359 seconds
Time Taken: 0.00862 seconds
Time Before: 0.05961 seconds
Time After: 0.06003 seconds
Time Before: 0.06340 seconds
Time After: 0.06462 seconds
Time Before: 0.05886 seconds
Time After: 0.06484 seconds
Time Taken: 0.00598 seconds
Time Before: 0.11524 seconds
Time After: 0.11537 seconds
Time Before: 0.13951 seconds
Time After: 0.14073 seconds
Time Before: 0.15062 seconds
Time After: 0.15079 seconds
Time Before: 0.15402 seconds
Time After: 0.15550 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106066', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.17659 seconds
Time After: 0.17688 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
