Time Before: 0.02594 seconds
Time After: 0.04122 seconds
Time Taken: 0.01529 seconds
Time Before: 0.04135 seconds
Time After: 0.04198 seconds
Time Taken: 0.00063 seconds
Time Before: 0.04229 seconds
Time After: 0.04263 seconds
Time Before: 0.04382 seconds
Time After: 0.04677 seconds
Time Taken: 0.00296 seconds
Time Before: 0.04270 seconds
Time After: 0.05166 seconds
Time Taken: 0.00896 seconds
Time Before: 0.06913 seconds
Time After: 0.06959 seconds
Time Before: 0.07213 seconds
Time After: 0.07337 seconds
Time Before: 0.06837 seconds
Time After: 0.07357 seconds
Time Taken: 0.00520 seconds
Time Before: 0.12590 seconds
Time After: 0.12612 seconds
Time Before: 0.16355 seconds
Time After: 0.16483 seconds
Time Before: 0.18286 seconds
Time After: 0.18307 seconds
Time Before: 0.18592 seconds
Time After: 0.18741 seconds
UPDATE session SET lastactivity = 1783505936, location = '/forums/private.php?do=newpm&explain=1&u=106092', badlocation = 1 WHERE sessionhash = 'f88c536979e48fd20a608e8efaf90f77'
Time Before: 0.20687 seconds
Time After: 0.20714 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
