Time Before: 0.00172 seconds
Time After: 0.00225 seconds
Time Before: 0.00232 seconds
Time After: 0.00289 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00317 seconds
Time After: 0.00332 seconds
Time Before: 0.00427 seconds
Time After: 0.00717 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00340 seconds
Time After: 0.01103 seconds
Time Taken: 0.00763 seconds
Time Before: 0.01360 seconds
Time After: 0.01402 seconds
Time Before: 0.01677 seconds
Time After: 0.01802 seconds
Time Before: 0.01273 seconds
Time After: 0.01827 seconds
Time Taken: 0.00554 seconds
Time Before: 0.02567 seconds
Time After: 0.02590 seconds
Time Before: 0.02872 seconds
Time After: 0.03004 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.032644987106323
Time Before: 0.03416 seconds
Time After: 0.03436 seconds
Time Before: 0.03677 seconds
Time After: 0.03824 seconds
SET lastactivity = 1785288875, location = '/forums/private.php?do=newpm&explain=1&u=106100', badlocation = 1
Time Before: 0.05298 seconds
Time After: 0.05339 seconds
Page generated in 0.052037000656128 seconds with 9 queries, spending 0.0089347362518311 doing MySQL queries and 0.043102264404297 doing PHP things.
