Time Before: 0.00148 seconds
Time After: 0.00209 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00216 seconds
Time After: 0.00268 seconds
Time Before: 0.00289 seconds
Time After: 0.00308 seconds
Time Before: 0.00376 seconds
Time After: 0.00623 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00312 seconds
Time After: 0.00956 seconds
Time Taken: 0.00644 seconds
Time Before: 0.01129 seconds
Time After: 0.01171 seconds
Time Before: 0.01451 seconds
Time After: 0.01582 seconds
Time Before: 0.01072 seconds
Time After: 0.01599 seconds
Time Taken: 0.00527 seconds
Time Before: 0.02099 seconds
Time After: 0.02123 seconds
Time Before: 0.02328 seconds
Time After: 0.02447 seconds
Time Before: 0.02752 seconds
Time After: 0.02765 seconds
Time Before: 0.03049 seconds
Time After: 0.03190 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106104' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.04500 seconds
Time After: 0.04532 seconds
