Time Before: 0.01531 seconds
Time After: 0.01767 seconds
Time Taken: 0.00236 seconds
Time Before: 0.01781 seconds
Time After: 0.01837 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01864 seconds
Time After: 0.01877 seconds
Time Before: 0.01979 seconds
Time After: 0.02272 seconds
Time Taken: 0.00293 seconds
Time Before: 0.01887 seconds
Time After: 0.02764 seconds
Time Taken: 0.00878 seconds
Time Before: 0.03299 seconds
Time After: 0.03336 seconds
Time Before: 0.03602 seconds
Time After: 0.03785 seconds
Time Taken: 0.00184 seconds
Time Before: 0.03231 seconds
Time After: 0.03812 seconds
Time Taken: 0.00581 seconds
Time Before: 0.05425 seconds
Time After: 0.05440 seconds
Time Before: 0.06780 seconds
Time After: 0.06900 seconds
Time Before: 0.07753 seconds
Time After: 0.07772 seconds
Time Before: 0.08097 seconds
Time After: 0.08240 seconds
UPDATE session SET lastactivity = 1783220448, location = '/forums/private.php?do=newpm&explain=1&u=106112', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.09908 seconds
Time After: 0.09937 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
