Time Before: 0.01875 seconds
Time After: 0.02459 seconds
Time Taken: 0.00584 seconds
Time Before: 0.02470 seconds
Time After: 0.02518 seconds
Time Before: 0.02540 seconds
Time After: 0.02553 seconds
Time Before: 0.02647 seconds
Time After: 0.03032 seconds
Time Taken: 0.00385 seconds
Time Before: 0.02559 seconds
Time After: 0.03423 seconds
Time Taken: 0.00864 seconds
Time Before: 0.03984 seconds
Time After: 0.04022 seconds
Time Before: 0.04294 seconds
Time After: 0.04416 seconds
Time Before: 0.03908 seconds
Time After: 0.04441 seconds
Time Taken: 0.00533 seconds
Time Before: 0.08202 seconds
Time After: 0.08223 seconds
Time Before: 0.09953 seconds
Time After: 0.10088 seconds
Time Taken: 0.00134 seconds
Time Before: 0.11191 seconds
Time After: 0.11212 seconds
Time Before: 0.11477 seconds
Time After: 0.11643 seconds
Time Taken: 0.00165 seconds
UPDATE session SET lastactivity = 1789068935, location = '/forums/private.php?do=newpm&explain=1&u=106173', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.13364 seconds
Time After: 0.13411 seconds
