Time Before: 0.00150 seconds
Time After: 0.00196 seconds
Time Before: 0.00203 seconds
Time After: 0.00256 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00298 seconds
Time After: 0.00337 seconds
Time Before: 0.00426 seconds
Time After: 0.00694 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00345 seconds
Time After: 0.01201 seconds
Time Taken: 0.00856 seconds
Time Before: 0.01408 seconds
Time After: 0.01454 seconds
Time Before: 0.01746 seconds
Time After: 0.01873 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01341 seconds
Time After: 0.01896 seconds
Time Taken: 0.00555 seconds
Memory After: 2,261.820 KB
Time Before: 0.02683 seconds
Time After: 0.02697 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02902 seconds
Time After: 0.03055 seconds
Time Taken: 0.00153 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.032270908355713
Time Before: 0.03397 seconds
Time After: 0.03442 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03734 seconds
Time After: 0.03877 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789016829, location = '/forums/private.php?do=newpm&explain=1&u=106180'
Time Before: 0.05410 seconds
Time After: 0.05446 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.052757978439331 seconds with 9 queries, spending 0.0092577934265137 doing MySQL queries and 0.043500185012817 doing PHP things.
