Time Before: 0.00136 seconds
Time After: 0.00181 seconds
Time Before: 0.00188 seconds
Time After: 0.00234 seconds
Time Before: 0.00260 seconds
Time After: 0.00277 seconds
Time Before: 0.00359 seconds
Time After: 0.00630 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00285 seconds
Time After: 0.00989 seconds
Time Taken: 0.00704 seconds
Time Before: 0.01206 seconds
Time After: 0.01244 seconds
Time Before: 0.01502 seconds
Time After: 0.01627 seconds
Time Before: 0.01135 seconds
Time After: 0.01653 seconds
Time Taken: 0.00517 seconds
Time Before: 0.02236 seconds
Time After: 0.02252 seconds
Time Before: 0.02456 seconds
Time After: 0.02580 seconds
End call of global.php: 0.027726173400879
Time Before: 0.02902 seconds
Time After: 0.02920 seconds
Time Before: 0.03174 seconds
Time After: 0.03319 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=106182'
Time Before: 0.04627 seconds
Time After: 0.04652 seconds
Page generated in 0.044974088668823 seconds with 9 queries, spending 0.0082340240478516 doing MySQL queries and 0.036740064620972 doing PHP things.
