Time Before: 0.00142 seconds
Time After: 0.00200 seconds
Time Taken: 0.00058 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00207 seconds
Time After: 0.00264 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00299 seconds
Time After: 0.00315 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00400 seconds
Time After: 0.00686 seconds
Time Taken: 0.00287 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00323 seconds
Time After: 0.01217 seconds
Time Taken: 0.00894 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01407 seconds
Time After: 0.01456 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01595 seconds
Time After: 0.01717 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01337 seconds
Time After: 0.01734 seconds
Time Taken: 0.00397 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.02416 seconds
Time After: 0.02431 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.02655 seconds
Time After: 0.02795 seconds
Time Taken: 0.00140 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
End call of global.php: 0.029593944549561
Time Before: 0.03073 seconds
Time After: 0.03091 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.03286 seconds
Time After: 0.03428 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=106207'
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04698 seconds
Time After: 0.04727 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
Page generated in 0.046109914779663 seconds with 9 queries, spending 0.0087442398071289 doing MySQL queries and 0.037365674972534 doing PHP things.
