Time Before: 0.00251 seconds
Time After: 0.00454 seconds
Time Taken: 0.00203 seconds
Time Before: 0.00463 seconds
Time After: 0.00506 seconds
Time Before: 0.00531 seconds
Time After: 0.00548 seconds
Time Before: 0.00636 seconds
Time After: 0.00852 seconds
Time Taken: 0.00216 seconds
Time Before: 0.00556 seconds
Time After: 0.01349 seconds
Time Taken: 0.00794 seconds
Time Before: 0.01753 seconds
Time After: 0.01795 seconds
Time Before: 0.02054 seconds
Time After: 0.02173 seconds
Time Before: 0.01679 seconds
Time After: 0.02195 seconds
Time Taken: 0.00516 seconds
Time Before: 0.03060 seconds
Time After: 0.03078 seconds
Time Before: 0.03473 seconds
Time After: 0.03601 seconds
End call of global.php: 0.038683891296387
Time Before: 0.04087 seconds
Time After: 0.04106 seconds
Time Before: 0.04417 seconds
Time After: 0.04575 seconds
Time Taken: 0.00158 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=106212', badlocation = 1
Time Before: 0.06565 seconds
Time After: 0.06592 seconds
Page generated in 0.064486026763916 seconds with 9 queries, spending 0.0078709125518799 doing MySQL queries and 0.056615114212036 doing PHP things.
