Time Before: 0.00568 seconds
Time After: 0.00676 seconds
Time Taken: 0.00108 seconds
Time Before: 0.00685 seconds
Time After: 0.00726 seconds
Time Before: 0.00750 seconds
Time After: 0.00762 seconds
Time Before: 0.00834 seconds
Time After: 0.01049 seconds
Time Taken: 0.00215 seconds
Time Before: 0.00766 seconds
Time After: 0.01410 seconds
Time Taken: 0.00644 seconds
Time Before: 0.01701 seconds
Time After: 0.01739 seconds
Time Before: 0.01989 seconds
Time After: 0.02111 seconds
Time Before: 0.01637 seconds
Time After: 0.02133 seconds
Time Taken: 0.00496 seconds
Time Before: 0.03451 seconds
Time After: 0.03467 seconds
Time Before: 0.03924 seconds
Time After: 0.04047 seconds
End call of global.php: 0.043020009994507
Time Before: 0.04533 seconds
Time After: 0.04556 seconds
Time Before: 0.04835 seconds
Time After: 0.04979 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=106223'
Time Before: 0.06856 seconds
Time After: 0.06883 seconds
Page generated in 0.067378044128418 seconds with 9 queries, spending 0.0076053142547607 doing MySQL queries and 0.059772729873657 doing PHP things.
