Time Before: 0.00161 seconds
Time After: 0.00234 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00241 seconds
Time After: 0.00300 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00324 seconds
Time After: 0.00338 seconds
Time Before: 0.00405 seconds
Time After: 0.00660 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00343 seconds
Time After: 0.00996 seconds
Time Taken: 0.00652 seconds
Time Before: 0.01192 seconds
Time After: 0.01223 seconds
Time Before: 0.01444 seconds
Time After: 0.01575 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01126 seconds
Time After: 0.01593 seconds
Time Taken: 0.00467 seconds
Time Before: 0.02083 seconds
Time After: 0.02103 seconds
Time Before: 0.08922 seconds
Time After: 0.09060 seconds
Time Taken: 0.00137 seconds
Time Before: 0.09508 seconds
Time After: 0.09524 seconds
Time Before: 0.09836 seconds
Time After: 0.09981 seconds
UPDATE session SET lastactivity = 1780665496, location = '/forums/private.php?do=newpm&explain=1&u=106224', badlocation = 1 WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.11364 seconds
Time After: 0.11394 seconds
