Time Before: 0.00203 seconds
Time After: 0.00268 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00279 seconds
Time After: 0.00343 seconds
Time Before: 0.00366 seconds
Time After: 0.00377 seconds
Time Before: 0.00448 seconds
Time After: 0.00705 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00382 seconds
Time After: 0.01065 seconds
Time Taken: 0.00684 seconds
Time Before: 0.01253 seconds
Time After: 0.01310 seconds
Time Taken: 0.00057 seconds
Time Before: 0.01567 seconds
Time After: 0.01685 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01193 seconds
Time After: 0.01703 seconds
Time Taken: 0.00510 seconds
Memory After: 2,261.820 KB
Time Before: 0.02356 seconds
Time After: 0.02377 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02584 seconds
Time After: 0.02703 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.03034 seconds
Time After: 0.03055 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03271 seconds
Time After: 0.03412 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788878400, location = '/forums/private.php?do=newpm&explain=1&u=106229' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04655 seconds
Time After: 0.04681 seconds
Memory Before: 4,288.359 KB
Memory After: 4,288.586 KB
