Time Before: 0.00151 seconds
Time After: 0.00252 seconds
Time Taken: 0.00100 seconds
Time Before: 0.00264 seconds
Time After: 0.00306 seconds
Time Before: 0.00329 seconds
Time After: 0.00343 seconds
Time Before: 0.00409 seconds
Time After: 0.00675 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00348 seconds
Time After: 0.01010 seconds
Time Taken: 0.00663 seconds
Time Before: 0.01178 seconds
Time After: 0.01215 seconds
Time Before: 0.01463 seconds
Time After: 0.01586 seconds
Time Before: 0.01122 seconds
Time After: 0.01604 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02167 seconds
Time After: 0.02180 seconds
Time Before: 0.02379 seconds
Time After: 0.02502 seconds
Time Before: 0.02806 seconds
Time After: 0.02823 seconds
Time Before: 0.03036 seconds
Time After: 0.03177 seconds
Time Taken: 0.00140 seconds
UPDATE session SET lastactivity = 1788894396, location = '/forums/private.php?do=newpm&explain=1&u=10623' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04481 seconds
Time After: 0.04518 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
