Time Before: 0.02329 seconds
Time After: 0.03162 seconds
Time Taken: 0.00833 seconds
Time Before: 0.03173 seconds
Time After: 0.03225 seconds
Time Before: 0.03253 seconds
Time After: 0.03273 seconds
Time Before: 0.03346 seconds
Time After: 0.03538 seconds
Time Taken: 0.00192 seconds
Time Before: 0.03280 seconds
Time After: 0.03970 seconds
Time Taken: 0.00691 seconds
Time Before: 0.04686 seconds
Time After: 0.04734 seconds
Time Before: 0.04924 seconds
Time After: 0.05050 seconds
Time Before: 0.04620 seconds
Time After: 0.05077 seconds
Time Taken: 0.00457 seconds
Time Before: 0.09188 seconds
Time After: 0.09203 seconds
Time Before: 0.10514 seconds
Time After: 0.10639 seconds
Time Before: 0.11521 seconds
Time After: 0.11539 seconds
Time Before: 0.11802 seconds
Time After: 0.11946 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106248' WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.13868 seconds
Time After: 0.13896 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
