Time Before: 0.00842 seconds
Time After: 0.01204 seconds
Time Taken: 0.00361 seconds
Time Before: 0.01211 seconds
Time After: 0.01255 seconds
Time Before: 0.01280 seconds
Time After: 0.01295 seconds
Time Before: 0.01369 seconds
Time After: 0.01623 seconds
Time Taken: 0.00253 seconds
Time Before: 0.01300 seconds
Time After: 0.01983 seconds
Time Taken: 0.00683 seconds
Time Before: 0.02497 seconds
Time After: 0.02536 seconds
Time Before: 0.02775 seconds
Time After: 0.02899 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02423 seconds
Time After: 0.02917 seconds
Time Taken: 0.00494 seconds
Memory After: 2,261.703 KB
Time Before: 0.04169 seconds
Time After: 0.04182 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.04988 seconds
Time After: 0.05113 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.05664 seconds
Time After: 0.05679 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.05934 seconds
Time After: 0.06079 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106249' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.07751 seconds
Time After: 0.07782 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
