Time Before: 0.00212 seconds
Time After: 0.00271 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00281 seconds
Time After: 0.00336 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00361 seconds
Time After: 0.00375 seconds
Time Before: 0.00453 seconds
Time After: 0.00729 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00384 seconds
Time After: 0.01284 seconds
Time Taken: 0.00901 seconds
Time Before: 0.01528 seconds
Time After: 0.01548 seconds
Time Before: 0.01788 seconds
Time After: 0.01915 seconds
Time Before: 0.01443 seconds
Time After: 0.01943 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02593 seconds
Time After: 0.02608 seconds
Time Before: 0.02827 seconds
Time After: 0.03012 seconds
Time Taken: 0.00185 seconds
Time Before: 0.03459 seconds
Time After: 0.03474 seconds
Time Before: 0.03766 seconds
Time After: 0.03909 seconds
UPDATE session SET lastactivity = 1782960393, location = '/forums/private.php?do=newpm&explain=1&u=106258' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.05285 seconds
Time After: 0.05320 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
