Time Before: 0.00189 seconds
Time After: 0.00254 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00261 seconds
Time After: 0.00328 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00352 seconds
Time After: 0.00369 seconds
Time Before: 0.00438 seconds
Time After: 0.00753 seconds
Time Taken: 0.00315 seconds
Time Before: 0.00375 seconds
Time After: 0.01096 seconds
Time Taken: 0.00721 seconds
Time Before: 0.01276 seconds
Time After: 0.01328 seconds
Time Before: 0.01492 seconds
Time After: 0.01720 seconds
Time Taken: 0.00227 seconds
Time Before: 0.01215 seconds
Time After: 0.01737 seconds
Time Taken: 0.00523 seconds
Time Before: 0.02358 seconds
Time After: 0.02381 seconds
Time Before: 0.02565 seconds
Time After: 0.02699 seconds
Time Taken: 0.00134 seconds
Time Before: 0.02992 seconds
Time After: 0.03010 seconds
Time Before: 0.03287 seconds
Time After: 0.03433 seconds
UPDATE session SET lastactivity = 1783177369, location = '/forums/private.php?do=newpm&explain=1&u=106280', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.05130 seconds
Time After: 0.05190 seconds
Time Taken: 0.00059 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
