Time Before: 0.01016 seconds
Time After: 0.01457 seconds
Time Taken: 0.00440 seconds
Time Before: 0.01468 seconds
Time After: 0.01515 seconds
Time Before: 0.01543 seconds
Time After: 0.01559 seconds
Time Before: 0.01645 seconds
Time After: 0.01902 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01567 seconds
Time After: 0.02294 seconds
Time Taken: 0.00727 seconds
Time Before: 0.02750 seconds
Time After: 0.02794 seconds
Time Before: 0.03046 seconds
Time After: 0.03170 seconds
Time Before: 0.02682 seconds
Time After: 0.03195 seconds
Time Taken: 0.00513 seconds
Time Before: 0.05487 seconds
Time After: 0.05507 seconds
Time Before: 0.06436 seconds
Time After: 0.06567 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.067924022674561
Time Before: 0.07068 seconds
Time After: 0.07088 seconds
Time Before: 0.07348 seconds
Time After: 0.07497 seconds
SET lastactivity = 1785293220, location = '/forums/private.php?do=newpm&explain=1&u=106295', badlocation = 1
Time Before: 0.09220 seconds
Time After: 0.09250 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.091268062591553 seconds with 9 queries, spending 0.0083696842193604 doing MySQL queries and 0.082898378372192 doing PHP things.
