Time Before: 0.00146 seconds
Time After: 0.00191 seconds
Time Before: 0.00199 seconds
Time After: 0.00252 seconds
Time Before: 0.00275 seconds
Time After: 0.00296 seconds
Time Before: 0.00381 seconds
Time After: 0.00760 seconds
Time Taken: 0.00379 seconds
Time Before: 0.00305 seconds
Time After: 0.01270 seconds
Time Taken: 0.00965 seconds
Time Before: 0.01458 seconds
Time After: 0.01495 seconds
Time Before: 0.01716 seconds
Time After: 0.01854 seconds
Time Taken: 0.00138 seconds
Time Before: 0.01400 seconds
Time After: 0.01871 seconds
Time Taken: 0.00471 seconds
Time Before: 0.02397 seconds
Time After: 0.02423 seconds
Time Before: 0.02614 seconds
Time After: 0.02744 seconds
Time Before: 0.03043 seconds
Time After: 0.03063 seconds
Time Before: 0.03265 seconds
Time After: 0.03407 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106297', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.04668 seconds
Time After: 0.04705 seconds
