Time Before: 0.02910 seconds
Time After: 0.03716 seconds
Time Taken: 0.00805 seconds
Time Before: 0.03726 seconds
Time After: 0.03772 seconds
Time Before: 0.03799 seconds
Time After: 0.03814 seconds
Time Before: 0.03887 seconds
Time After: 0.04084 seconds
Time Taken: 0.00197 seconds
Time Before: 0.03821 seconds
Time After: 0.04674 seconds
Time Taken: 0.00853 seconds
Time Before: 0.05523 seconds
Time After: 0.05555 seconds
Time Before: 0.05812 seconds
Time After: 0.05934 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05450 seconds
Time After: 0.05955 seconds
Time Taken: 0.00505 seconds
Memory After: 2,261.703 KB
Time Before: 0.10015 seconds
Time After: 0.10030 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.24745 seconds
Time After: 0.24867 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.26350 seconds
Time After: 0.26365 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.26739 seconds
Time After: 0.27152 seconds
Time Taken: 0.00413 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106314' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.29070 seconds
Time After: 0.29105 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
