Time Before: 0.01164 seconds
Time After: 0.01631 seconds
Time Taken: 0.00468 seconds
Time Before: 0.01640 seconds
Time After: 0.01685 seconds
Time Before: 0.01708 seconds
Time After: 0.01721 seconds
Time Before: 0.01794 seconds
Time After: 0.02024 seconds
Time Taken: 0.00230 seconds
Time Before: 0.01727 seconds
Time After: 0.02446 seconds
Time Taken: 0.00719 seconds
Time Before: 0.03003 seconds
Time After: 0.03024 seconds
Time Before: 0.03274 seconds
Time After: 0.03405 seconds
Time Taken: 0.00131 seconds
Time Before: 0.02934 seconds
Time After: 0.03426 seconds
Time Taken: 0.00492 seconds
Time Before: 0.05198 seconds
Time After: 0.05215 seconds
Time Before: 0.24124 seconds
Time After: 0.24250 seconds
Time Before: 0.24988 seconds
Time After: 0.25006 seconds
Time Before: 0.25287 seconds
Time After: 0.25436 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106324', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.27237 seconds
Time After: 0.27260 seconds
