Time Before: 0.02380 seconds
Time After: 0.03182 seconds
Time Taken: 0.00803 seconds
Time Before: 0.03192 seconds
Time After: 0.03235 seconds
Time Before: 0.03259 seconds
Time After: 0.03274 seconds
Time Before: 0.03355 seconds
Time After: 0.03697 seconds
Time Taken: 0.00342 seconds
Time Before: 0.03281 seconds
Time After: 0.04156 seconds
Time Taken: 0.00875 seconds
Time Before: 0.05400 seconds
Time After: 0.05439 seconds
Time Before: 0.05681 seconds
Time After: 0.05804 seconds
Time Before: 0.05340 seconds
Time After: 0.05822 seconds
Time Taken: 0.00483 seconds
Time Before: 0.08931 seconds
Time After: 0.08948 seconds
Time Before: 0.11850 seconds
Time After: 0.11973 seconds
End call of global.php: 0.1220908164978
Time Before: 0.13142 seconds
Time After: 0.13162 seconds
Time Before: 0.13409 seconds
Time After: 0.13556 seconds
SET lastactivity = 1783201250, location = '/forums/private.php?do=newpm&explain=1&u=106327', badlocation = 1
Time Before: 0.15557 seconds
Time After: 0.15587 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
Page generated in 0.15418291091919 seconds with 9 queries, spending 0.0089876651763916 doing MySQL queries and 0.1451952457428 doing PHP things.
