Time Before: 0.00146 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00259 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00286 seconds
Time After: 0.00302 seconds
Time Before: 0.00368 seconds
Time After: 0.00636 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00307 seconds
Time After: 0.00974 seconds
Time Taken: 0.00667 seconds
Time Before: 0.01151 seconds
Time After: 0.01196 seconds
Time Before: 0.01464 seconds
Time After: 0.01591 seconds
Time Before: 0.01094 seconds
Time After: 0.01607 seconds
Time Taken: 0.00513 seconds
Time Before: 0.02198 seconds
Time After: 0.02217 seconds
Time Before: 0.02454 seconds
Time After: 0.02591 seconds
Time Taken: 0.00137 seconds
Time Before: 0.03001 seconds
Time After: 0.03019 seconds
Time Before: 0.03296 seconds
Time After: 0.03439 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106329', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.04827 seconds
Time After: 0.04860 seconds
