Time Before: 0.03132 seconds
Time After: 0.03912 seconds
Time Taken: 0.00780 seconds
Time Before: 0.03920 seconds
Time After: 0.03970 seconds
Time Before: 0.03995 seconds
Time After: 0.04018 seconds
Time Before: 0.04116 seconds
Time After: 0.04385 seconds
Time Taken: 0.00269 seconds
Time Before: 0.04026 seconds
Time After: 0.04794 seconds
Time Taken: 0.00768 seconds
Time Before: 0.05672 seconds
Time After: 0.05736 seconds
Time Taken: 0.00064 seconds
Time Before: 0.05895 seconds
Time After: 0.06135 seconds
Time Taken: 0.00240 seconds
Time Before: 0.05588 seconds
Time After: 0.06163 seconds
Time Taken: 0.00575 seconds
Time Before: 0.11130 seconds
Time After: 0.11152 seconds
Time Before: 0.13027 seconds
Time After: 0.13158 seconds
Time Taken: 0.00131 seconds
Time Before: 0.14190 seconds
Time After: 0.14215 seconds
Time Before: 0.14524 seconds
Time After: 0.14677 seconds
Time Taken: 0.00153 seconds
UPDATE session SET lastactivity = 1776458492, location = '/forums/private.php?do=newpm&explain=1&u=106347' WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.16826 seconds
Time After: 0.16866 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
