Time Before: 0.00175 seconds
Time After: 0.00250 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00257 seconds
Time After: 0.00323 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00358 seconds
Time After: 0.00371 seconds
Time Before: 0.00446 seconds
Time After: 0.00700 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00377 seconds
Time After: 0.01042 seconds
Time Taken: 0.00665 seconds
Time Before: 0.01237 seconds
Time After: 0.01275 seconds
Time Before: 0.01518 seconds
Time After: 0.01660 seconds
Time Before: 0.01180 seconds
Time After: 0.01680 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02221 seconds
Time After: 0.02236 seconds
Time Before: 0.02475 seconds
Time After: 0.02604 seconds
End call of global.php: 0.027781009674072
Time Before: 0.02915 seconds
Time After: 0.02931 seconds
Time Before: 0.03128 seconds
Time After: 0.03271 seconds
SET lastactivity = 1783138071, location = '/forums/private.php?do=newpm&explain=1&u=106353', badlocation = 1
Time Before: 0.04534 seconds
Time After: 0.04826 seconds
Time Taken: 0.00292 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
Page generated in 0.044458150863647 seconds with 9 queries, spending 0.011074781417847 doing MySQL queries and 0.033383369445801 doing PHP things.
