Time Before: 0.00246 seconds
Time After: 0.00343 seconds
Time Taken: 0.00097 seconds
Time Before: 0.00350 seconds
Time After: 0.00387 seconds
Time Before: 0.00409 seconds
Time After: 0.00424 seconds
Time Before: 0.00494 seconds
Time After: 0.00740 seconds
Time Taken: 0.00246 seconds
Time Before: 0.00429 seconds
Time After: 0.01086 seconds
Time Taken: 0.00657 seconds
Time Before: 0.01283 seconds
Time After: 0.01325 seconds
Time Before: 0.01629 seconds
Time After: 0.01753 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01209 seconds
Time After: 0.01778 seconds
Time Taken: 0.00569 seconds
Memory After: 2,261.703 KB
Time Before: 0.02459 seconds
Time After: 0.02482 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02686 seconds
Time After: 0.02808 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.03103 seconds
Time After: 0.03117 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03319 seconds
Time After: 0.03467 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106360', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04895 seconds
Time After: 0.04957 seconds
Time Taken: 0.00062 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
