Time Before: 0.00737 seconds
Time After: 0.00886 seconds
Time Before: 0.00900 seconds
Time After: 0.00939 seconds
Time Before: 0.00961 seconds
Time After: 0.00972 seconds
Time Before: 0.01052 seconds
Time After: 0.01272 seconds
Time Taken: 0.00220 seconds
Time Before: 0.00979 seconds
Time After: 0.01706 seconds
Time Taken: 0.00726 seconds
Time Before: 0.02017 seconds
Time After: 0.02055 seconds
Time Before: 0.02250 seconds
Time After: 0.02465 seconds
Time Taken: 0.00215 seconds
Time Before: 0.01947 seconds
Time After: 0.02494 seconds
Time Taken: 0.00547 seconds
Time Before: 0.04104 seconds
Time After: 0.04116 seconds
Time Before: 0.04644 seconds
Time After: 0.04768 seconds
End call of global.php: 0.04970908164978
Time Before: 0.05253 seconds
Time After: 0.05267 seconds
Time Before: 0.05484 seconds
Time After: 0.05625 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=106375', badlocation = 1
Time Before: 0.07380 seconds
Time After: 0.07416 seconds
Page generated in 0.072606086730957 seconds with 9 queries, spending 0.0085010528564453 doing MySQL queries and 0.064105033874512 doing PHP things.
