Time Before: 0.00318 seconds
Time After: 0.00374 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00380 seconds
Time After: 0.00441 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00461 seconds
Time After: 0.00475 seconds
Time Before: 0.00569 seconds
Time After: 0.00798 seconds
Time Taken: 0.00229 seconds
Time Before: 0.00480 seconds
Time After: 0.01138 seconds
Time Taken: 0.00658 seconds
Time Before: 0.01353 seconds
Time After: 0.01393 seconds
Time Before: 0.01715 seconds
Time After: 0.01831 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01279 seconds
Time After: 0.01849 seconds
Time Taken: 0.00569 seconds
Memory After: 2,261.820 KB
Time Before: 0.02356 seconds
Time After: 0.02373 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02627 seconds
Time After: 0.02872 seconds
Time Taken: 0.00245 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.030312061309814
Time Before: 0.03186 seconds
Time After: 0.03213 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03417 seconds
Time After: 0.03563 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789023544, location = '/forums/private.php?do=newpm&explain=1&u=106376'
Time Before: 0.05159 seconds
Time After: 0.05192 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.050375938415527 seconds with 9 queries, spending 0.0092663764953613 doing MySQL queries and 0.041109561920166 doing PHP things.
