Time Before: 0.00207 seconds
Time After: 0.00253 seconds
Time Before: 0.00260 seconds
Time After: 0.00297 seconds
Time Before: 0.00317 seconds
Time After: 0.00334 seconds
Time Before: 0.00401 seconds
Time After: 0.00648 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00339 seconds
Time After: 0.00998 seconds
Time Taken: 0.00659 seconds
Time Before: 0.01352 seconds
Time After: 0.01389 seconds
Time Before: 0.01662 seconds
Time After: 0.01796 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01277 seconds
Time After: 0.01821 seconds
Time Taken: 0.00544 seconds
Time Before: 0.02477 seconds
Time After: 0.02494 seconds
Time Before: 0.02800 seconds
Time After: 0.02937 seconds
Time Taken: 0.00137 seconds
End call of global.php: 0.031109094619751
Time Before: 0.03231 seconds
Time After: 0.03246 seconds
Time Before: 0.03459 seconds
Time After: 0.03604 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=106391'
Time Before: 0.05203 seconds
Time After: 0.05227 seconds
Page generated in 0.050935029983521 seconds with 9 queries, spending 0.0081126689910889 doing MySQL queries and 0.042822360992432 doing PHP things.
