Time Before: 0.02517 seconds
Time After: 0.03108 seconds
Time Taken: 0.00591 seconds
Time Before: 0.03116 seconds
Time After: 0.03153 seconds
Time Before: 0.03175 seconds
Time After: 0.03186 seconds
Time Before: 0.03252 seconds
Time After: 0.03574 seconds
Time Taken: 0.00322 seconds
Time Before: 0.03191 seconds
Time After: 0.04012 seconds
Time Taken: 0.00821 seconds
Time Before: 0.05325 seconds
Time After: 0.05360 seconds
Time Before: 0.05507 seconds
Time After: 0.05630 seconds
Time Before: 0.05262 seconds
Time After: 0.05661 seconds
Time Taken: 0.00400 seconds
Time Before: 0.10461 seconds
Time After: 0.10475 seconds
Time Before: 0.12513 seconds
Time After: 0.12636 seconds
Time Before: 0.13691 seconds
Time After: 0.13714 seconds
Time Before: 0.13959 seconds
Time After: 0.14112 seconds
Time Taken: 0.00154 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106397', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.16170 seconds
Time After: 0.16194 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
