Time Before: 0.01290 seconds
Time After: 0.01605 seconds
Time Taken: 0.00315 seconds
Time Before: 0.01618 seconds
Time After: 0.01670 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01700 seconds
Time After: 0.01714 seconds
Time Before: 0.01796 seconds
Time After: 0.02024 seconds
Time Taken: 0.00228 seconds
Time Before: 0.01721 seconds
Time After: 0.02492 seconds
Time Taken: 0.00771 seconds
Time Before: 0.02987 seconds
Time After: 0.03025 seconds
Time Before: 0.03176 seconds
Time After: 0.03362 seconds
Time Taken: 0.00186 seconds
Time Before: 0.02913 seconds
Time After: 0.03383 seconds
Time Taken: 0.00470 seconds
Time Before: 0.05923 seconds
Time After: 0.05937 seconds
Time Before: 0.06828 seconds
Time After: 0.06957 seconds
End call of global.php: 0.071764945983887
Time Before: 0.07693 seconds
Time After: 0.07711 seconds
Time Before: 0.07975 seconds
Time After: 0.08116 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=106407', badlocation = 1
Time Before: 0.09649 seconds
Time After: 0.09679 seconds
Page generated in 0.095415830612183 seconds with 9 queries, spending 0.0084843635559082 doing MySQL queries and 0.086931467056274 doing PHP things.
