Time Before: 0.00140 seconds
Time After: 0.00191 seconds
Time Before: 0.00199 seconds
Time After: 0.00238 seconds
Time Before: 0.00256 seconds
Time After: 0.00270 seconds
Time Before: 0.00342 seconds
Time After: 0.00554 seconds
Time Taken: 0.00212 seconds
Time Before: 0.00275 seconds
Time After: 0.00897 seconds
Time Taken: 0.00623 seconds
Time Before: 0.01081 seconds
Time After: 0.01129 seconds
Time Before: 0.01430 seconds
Time After: 0.01549 seconds
Time Before: 0.01016 seconds
Time After: 0.01567 seconds
Time Taken: 0.00551 seconds
Time Before: 0.02081 seconds
Time After: 0.02101 seconds
Time Before: 0.02311 seconds
Time After: 0.02432 seconds
End call of global.php: 0.026041984558105
Time Before: 0.02737 seconds
Time After: 0.02762 seconds
Time Before: 0.02985 seconds
Time After: 0.03131 seconds
SET lastactivity = 1785352864, location = '/forums/private.php?do=newpm&explain=1&u=106414', badlocation = 1
Time Before: 0.04581 seconds
Time After: 0.04613 seconds
Page generated in 0.044906139373779 seconds with 9 queries, spending 0.0077581405639648 doing MySQL queries and 0.037147998809814 doing PHP things.
