Time Before: 0.02697 seconds
Time After: 0.03396 seconds
Time Taken: 0.00699 seconds
Time Before: 0.03406 seconds
Time After: 0.03457 seconds
Time Before: 0.03481 seconds
Time After: 0.03498 seconds
Time Before: 0.03580 seconds
Time After: 0.03804 seconds
Time Taken: 0.00224 seconds
Time Before: 0.03504 seconds
Time After: 0.04344 seconds
Time Taken: 0.00840 seconds
Time Before: 0.05398 seconds
Time After: 0.05482 seconds
Time Taken: 0.00084 seconds
Time Before: 0.05741 seconds
Time After: 0.05864 seconds
Time Before: 0.05329 seconds
Time After: 0.05889 seconds
Time Taken: 0.00559 seconds
Time Before: 0.09713 seconds
Time After: 0.09763 seconds
Time Before: 0.11794 seconds
Time After: 0.12016 seconds
Time Taken: 0.00222 seconds
Time Before: 0.13114 seconds
Time After: 0.13131 seconds
Time Before: 0.13400 seconds
Time After: 0.13552 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1789085676, location = '/forums/private.php?do=newpm&explain=1&u=106420', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.15702 seconds
Time After: 0.15734 seconds
