Time Before: 0.00164 seconds
Time After: 0.00218 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00225 seconds
Time After: 0.00285 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00310 seconds
Time After: 0.00327 seconds
Time Before: 0.00416 seconds
Time After: 0.00712 seconds
Time Taken: 0.00296 seconds
Time Before: 0.00332 seconds
Time After: 0.01203 seconds
Time Taken: 0.00871 seconds
Time Before: 0.01412 seconds
Time After: 0.01456 seconds
Time Before: 0.01707 seconds
Time After: 0.01839 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01344 seconds
Time After: 0.01858 seconds
Time Taken: 0.00514 seconds
Time Before: 0.02407 seconds
Time After: 0.02426 seconds
Time Before: 0.02678 seconds
Time After: 0.02813 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.029761075973511
Time Before: 0.03106 seconds
Time After: 0.03123 seconds
Time Before: 0.03317 seconds
Time After: 0.03465 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=106424'
Time Before: 0.04891 seconds
Time After: 0.04942 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.047941923141479 seconds with 9 queries, spending 0.0091917514801025 doing MySQL queries and 0.038750171661377 doing PHP things.
