Time Before: 0.00924 seconds
Time After: 0.01653 seconds
Time Taken: 0.00730 seconds
Time Before: 0.01664 seconds
Time After: 0.01713 seconds
Time Before: 0.01739 seconds
Time After: 0.01755 seconds
Time Before: 0.01851 seconds
Time After: 0.02095 seconds
Time Taken: 0.00244 seconds
Time Before: 0.01764 seconds
Time After: 0.02480 seconds
Time Taken: 0.00717 seconds
Time Before: 0.03060 seconds
Time After: 0.03111 seconds
Time Before: 0.03422 seconds
Time After: 0.03541 seconds
Time Before: 0.02990 seconds
Time After: 0.03560 seconds
Time Taken: 0.00571 seconds
Time Before: 0.05003 seconds
Time After: 0.05055 seconds
Time Taken: 0.00053 seconds
Time Before: 0.06493 seconds
Time After: 0.06682 seconds
Time Taken: 0.00189 seconds
Time Before: 0.07644 seconds
Time After: 0.07661 seconds
Time Before: 0.07885 seconds
Time After: 0.08027 seconds
UPDATE session SET lastactivity = 1789145853, location = '/forums/private.php?do=newpm&explain=1&u=106425', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.09611 seconds
Time After: 0.09642 seconds
