Time Before: 0.00143 seconds
Time After: 0.00190 seconds
Time Before: 0.00198 seconds
Time After: 0.00261 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00285 seconds
Time After: 0.00295 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00366 seconds
Time After: 0.00634 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00300 seconds
Time After: 0.00972 seconds
Time Taken: 0.00672 seconds
Time Before: 0.01174 seconds
Time After: 0.01212 seconds
Time Before: 0.01484 seconds
Time After: 0.01602 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01097 seconds
Time After: 0.01629 seconds
Time Taken: 0.00532 seconds
Time Before: 0.02264 seconds
Time After: 0.02283 seconds
Time Before: 0.02496 seconds
Time After: 0.02616 seconds
End call of global.php: 0.027806043624878
Time Before: 0.02907 seconds
Time After: 0.02925 seconds
Time Before: 0.03137 seconds
Time After: 0.03278 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=106440'
Time Before: 0.04550 seconds
Time After: 0.04587 seconds
Page generated in 0.044628143310547 seconds with 9 queries, spending 0.008307933807373 doing MySQL queries and 0.036320209503174 doing PHP things.
