Time Before: 0.01771 seconds
Time After: 0.02335 seconds
Time Taken: 0.00564 seconds
Time Before: 0.02345 seconds
Time After: 0.02392 seconds
Time Before: 0.02417 seconds
Time After: 0.02430 seconds
Time Before: 0.02508 seconds
Time After: 0.02742 seconds
Time Taken: 0.00234 seconds
Time Before: 0.02438 seconds
Time After: 0.03205 seconds
Time Taken: 0.00768 seconds
Time Before: 0.03889 seconds
Time After: 0.03933 seconds
Time Before: 0.04244 seconds
Time After: 0.04361 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03810 seconds
Time After: 0.04384 seconds
Time Taken: 0.00574 seconds
Memory After: 2,261.703 KB
Time Before: 0.06299 seconds
Time After: 0.06313 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.07476 seconds
Time After: 0.07603 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.08220 seconds
Time After: 0.08237 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.08451 seconds
Time After: 0.08594 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106448' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.10052 seconds
Time After: 0.10087 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
