Time Before: 0.00192 seconds
Time After: 0.00238 seconds
Time Before: 0.00245 seconds
Time After: 0.00282 seconds
Time Before: 0.00305 seconds
Time After: 0.00317 seconds
Time Before: 0.00388 seconds
Time After: 0.00656 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00325 seconds
Time After: 0.01171 seconds
Time Taken: 0.00846 seconds
Time Before: 0.01360 seconds
Time After: 0.01401 seconds
Time Before: 0.01691 seconds
Time After: 0.01809 seconds
Time Before: 0.01288 seconds
Time After: 0.01835 seconds
Time Taken: 0.00547 seconds
Time Before: 0.02501 seconds
Time After: 0.02513 seconds
Time Before: 0.02730 seconds
Time After: 0.02856 seconds
Time Before: 0.03314 seconds
Time After: 0.03330 seconds
Time Before: 0.03676 seconds
Time After: 0.03827 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1785290406, location = '/forums/private.php?do=newpm&explain=1&u=106454' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.05210 seconds
Time After: 0.05245 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
