Time Before: 0.00239 seconds
Time After: 0.00307 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00320 seconds
Time After: 0.00372 seconds
Time Before: 0.00401 seconds
Time After: 0.00415 seconds
Time Before: 0.00521 seconds
Time After: 0.00769 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00423 seconds
Time After: 0.01395 seconds
Time Taken: 0.00972 seconds
Time Before: 0.01649 seconds
Time After: 0.01675 seconds
Time Before: 0.01879 seconds
Time After: 0.02007 seconds
Time Before: 0.01565 seconds
Time After: 0.02025 seconds
Time Taken: 0.00460 seconds
Time Before: 0.02613 seconds
Time After: 0.02627 seconds
Time Before: 6.34582 seconds
Time After: 6.34754 seconds
Time Taken: 0.00172 seconds
End call of global.php: 6.3505299091339
Time Before: 6.35179 seconds
Time After: 6.35195 seconds
Time Before: 6.35464 seconds
Time After: 6.35612 seconds
SET lastactivity = 1776704534, location = '/forums/private.php?do=newpm&explain=1&u=106462', badlocation = 1
Time Before: 6.36954 seconds
Time After: 6.36980 seconds
Page generated in 6.3686189651489 seconds with 9 queries, spending 0.0084431171417236 doing MySQL queries and 6.3601758480072 doing PHP things.
