Time Before: 0.00258 seconds
Time After: 0.00319 seconds
Time Taken: 0.00061 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00327 seconds
Time After: 0.00375 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00401 seconds
Time After: 0.00417 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00482 seconds
Time After: 0.00802 seconds
Time Taken: 0.00320 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00423 seconds
Time After: 0.01148 seconds
Time Taken: 0.00725 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01340 seconds
Time After: 0.01386 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01661 seconds
Time After: 0.01791 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01274 seconds
Time After: 0.01808 seconds
Time Taken: 0.00535 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02472 seconds
Time After: 0.02495 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03204 seconds
Time After: 0.03328 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.04143 seconds
Time After: 0.04161 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04393 seconds
Time After: 0.04535 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106466', badlocation = 1 WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.05892 seconds
Time After: 0.05929 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
