Time Before: 0.02410 seconds
Time After: 0.03193 seconds
Time Taken: 0.00783 seconds
Time Before: 0.03201 seconds
Time After: 0.03255 seconds
Time Taken: 0.00054 seconds
Time Before: 0.03283 seconds
Time After: 0.03299 seconds
Time Before: 0.03380 seconds
Time After: 0.03643 seconds
Time Taken: 0.00264 seconds
Time Before: 0.03307 seconds
Time After: 0.04015 seconds
Time Taken: 0.00708 seconds
Time Before: 0.05128 seconds
Time After: 0.05149 seconds
Time Before: 0.05293 seconds
Time After: 0.05413 seconds
Time Before: 0.05068 seconds
Time After: 0.05434 seconds
Time Taken: 0.00366 seconds
Time Before: 0.08955 seconds
Time After: 0.08970 seconds
Time Before: 0.11039 seconds
Time After: 0.11166 seconds
Time Before: 0.12048 seconds
Time After: 0.12070 seconds
Time Before: 0.12288 seconds
Time After: 0.12434 seconds
UPDATE session SET lastactivity = 1783074855, location = '/forums/private.php?do=newpm&explain=1&u=106475', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.14349 seconds
Time After: 0.14378 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
