Time Before: 0.00143 seconds
Time After: 0.00195 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00208 seconds
Time After: 0.00260 seconds
Time Before: 0.00285 seconds
Time After: 0.00302 seconds
Time Before: 0.00368 seconds
Time After: 0.00642 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00307 seconds
Time After: 0.00977 seconds
Time Taken: 0.00670 seconds
Time Before: 0.01162 seconds
Time After: 0.01196 seconds
Time Before: 0.01348 seconds
Time After: 0.01467 seconds
Time Before: 0.01104 seconds
Time After: 0.01484 seconds
Time Taken: 0.00380 seconds
Time Before: 0.01973 seconds
Time After: 0.01991 seconds
Time Before: 0.02174 seconds
Time After: 0.02295 seconds
Time Before: 0.02568 seconds
Time After: 0.02580 seconds
Time Before: 0.02777 seconds
Time After: 0.02919 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106492' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04144 seconds
Time After: 0.04183 seconds
