Time Before: 0.02648 seconds
Time After: 0.03598 seconds
Time Taken: 0.00949 seconds
Time Before: 0.03609 seconds
Time After: 0.03655 seconds
Time Before: 0.03680 seconds
Time After: 0.03694 seconds
Time Before: 0.03768 seconds
Time After: 0.04003 seconds
Time Taken: 0.00235 seconds
Time Before: 0.03700 seconds
Time After: 0.04418 seconds
Time Taken: 0.00719 seconds
Time Before: 0.05518 seconds
Time After: 0.05558 seconds
Time Before: 0.05803 seconds
Time After: 0.05923 seconds
Time Before: 0.05451 seconds
Time After: 0.05950 seconds
Time Taken: 0.00499 seconds
Time Before: 0.10321 seconds
Time After: 0.10340 seconds
Time Before: 0.15797 seconds
Time After: 0.15922 seconds
Time Before: 0.17176 seconds
Time After: 0.17196 seconds
Time Before: 0.17457 seconds
Time After: 0.17603 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106496' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.19239 seconds
Time After: 0.19268 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
