Time Before: 0.00207 seconds
Time After: 0.00266 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00277 seconds
Time After: 0.00323 seconds
Time Before: 0.00346 seconds
Time After: 0.00360 seconds
Time Before: 0.00446 seconds
Time After: 0.00659 seconds
Time Taken: 0.00213 seconds
Time Before: 0.00367 seconds
Time After: 0.01014 seconds
Time Taken: 0.00647 seconds
Time Before: 0.01202 seconds
Time After: 0.01242 seconds
Time Before: 0.01387 seconds
Time After: 0.01504 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01138 seconds
Time After: 0.01523 seconds
Time Taken: 0.00385 seconds
Time Before: 0.02104 seconds
Time After: 0.02118 seconds
Time Before: 1.17943 seconds
Time After: 1.18104 seconds
Time Taken: 0.00160 seconds
Time Before: 1.18491 seconds
Time After: 1.18507 seconds
Time Before: 1.18739 seconds
Time After: 1.18885 seconds
UPDATE session SET lastactivity = 1788982187, location = '/forums/private.php?do=newpm&explain=1&u=106498' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 1.20231 seconds
Time After: 1.20256 seconds
