Time Before: 0.00222 seconds
Time After: 0.00284 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00291 seconds
Time After: 0.00333 seconds
Time Before: 0.00351 seconds
Time After: 0.00362 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00426 seconds
Time After: 0.00696 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00366 seconds
Time After: 0.01243 seconds
Time Taken: 0.00877 seconds
Time Before: 0.01494 seconds
Time After: 0.01534 seconds
Time Before: 0.01806 seconds
Time After: 0.02023 seconds
Time Taken: 0.00216 seconds
Time Before: 0.01410 seconds
Time After: 0.02052 seconds
Time Taken: 0.00642 seconds
Time Before: 0.02692 seconds
Time After: 0.02705 seconds
Time Before: 0.02896 seconds
Time After: 0.03030 seconds
Time Taken: 0.00134 seconds
Time Before: 0.03498 seconds
Time After: 0.03514 seconds
Time Before: 0.03843 seconds
Time After: 0.03985 seconds
UPDATE session SET lastactivity = 1788949006, location = '/forums/private.php?do=newpm&explain=1&u=106542' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.05685 seconds
Time After: 0.05726 seconds
