Time Before: 0.01409 seconds
Time After: 0.01915 seconds
Time Taken: 0.00506 seconds
Time Before: 0.01925 seconds
Time After: 0.01962 seconds
Time Before: 0.01985 seconds
Time After: 0.02004 seconds
Time Before: 0.02079 seconds
Time After: 0.02317 seconds
Time Taken: 0.00238 seconds
Time Before: 0.02010 seconds
Time After: 0.02824 seconds
Time Taken: 0.00814 seconds
Time Before: 0.03306 seconds
Time After: 0.03352 seconds
Time Before: 0.03599 seconds
Time After: 0.03725 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03236 seconds
Time After: 0.03747 seconds
Time Taken: 0.00511 seconds
Memory After: 2,261.820 KB
Time Before: 0.06132 seconds
Time After: 0.06149 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.07009 seconds
Time After: 0.07135 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.07824 seconds
Time After: 0.07842 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.08119 seconds
Time After: 0.08270 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788979333, location = '/forums/private.php?do=newpm&explain=1&u=106562' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.09990 seconds
Time After: 0.10804 seconds
Time Taken: 0.00815 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
